Restricted performance
Old Jun 2, 2016 | 04:50 PM
pedromechani c's Avatar
Default Restricted performance
My forum family.I desparately need your help, my 2000 xj8 with 104k miles is showing restricted performance with code Po357 and Po307 .I've replaced #7 coil,all plugs,fuel filter and fuel pressure regulator to no avail I've also swap the new #7 coil with # 3 to eliminate bad from stock possibility. After clearing all codes I start the car all the above codes return any advice as to what to do next would be greatly appreciated thanks in advance
Old Jun 3, 2016 | 02:16 AM
JagV8's Avatar
Check wiring.
BTW You mean P0 not Po
Old Jun 3, 2016 | 08:04 AM
Fraser Mitchell's Avatar
Sorry, Pedro, wrong forum. This one is for the model after yours, so post in the X308 forum for a better response.
Old Jun 3, 2016 | 09:37 AM
Don B's Avatar
pedromechani c,
I have moved your thread from the forum for the X350 to the forum for the X308, which is the Jaguar factory project code for your 2000 XJ8. Here you will find knowledgeable owners of similar cars.
Cheers,
Don
Old Jun 3, 2016 | 10:22 AM
pjdarcy's Avatar
Is the engine mis-firing?
Old Jun 4, 2016 | 07:58 AM
Yes
Old Jun 4, 2016 | 08:02 AM
Thanks Don 8, will post there from now on
Old Jun 4, 2016 | 08:15 AM
pjdarcy's Avatar
It's possible that the misfire is causing the crank position sensor to send an error to the ecu. Have you got good compression in cylinder number 7 and a strong spark on that plug?
Here's a link to a video on troubleshooting misfires
Jennifer S Flavell
Jun 20, 2016 05:19 AM
NICKGTD40
Jun 3, 2016 02:26 AM
fishface5
Jun 2, 2016 12:41 PM
RonaldP
Jun 1, 2016 04:59 PM
tony bosco
May 30, 2016 04:41 PM
