Restricted Performance, sputter, and hesitation
Old Dec 12, 2016 | 06:58 AM
user 652867429824's Avatar
Banned
Default Restricted Performance, sputter, and hesitation
Thought I resolved the Restricted Performance since my last post on this, but coming home from shopping it came up again, only this time the VDP stumbled and hesitated a bit a couple of time on the way back. I have also noticed it has been a bit hard starting the past week but attributed that it may be due to the Arctic Air blowing in.
I have a couple of ideas on things to check, but would be appreciated on some other input. Oh, also have the Lean Codes for bank 1 and 2, and when doing system checks with the reader, I noticed that injector 2 on both banks are off even with the car running, so I figure on checking the injectors (maybe just change them all since my son sent me a set he had for same engine/motor), how should I check the injector connectors to see if power is coming thru.
Old Dec 12, 2016 | 10:39 AM
Addicted2boost's Avatar
If that battery is in very cold climate like your stating, I'd get a battery warmer and/or tender. If that battery is over 3 years old, I'd heavily lean towards a new high quality replacement battery. Before looking at anything else (including injectors), the battery needs to be dealt with first. Then do a hard reset.
Old Dec 12, 2016 | 11:32 AM
Banned
Thanks, I will look into that today, since I was "Old Show school" trained on cars and haven't worked on them for many, many yrs, I am so grateful for the help and the help from the forum. Do you remember to how do the hard reset
Old Dec 12, 2016 | 12:02 PM
RJ237's Avatar
Remove the ground cable from the battery and touch it to the positive post for a few seconds.
Old Dec 12, 2016 | 05:56 PM
JagV8's Avatar
Hard to see how both banks would suddenly have the same injector go bad so you're probably looking for another explanation.
Old Dec 13, 2016 | 02:41 AM
Banned
I thought the same thing, could be a false reading from my code reader, or something else, after I bought it I had already planned on doing some things, some myself and some at the garage I use. I figured since I will have it in there I will have them hook up their code reader, that only cost $69. and that sure is cheap ,But that will wait until about next week since the girlfriends van is going in the shop and she hates getting into the XJS. LOL she enjoys the ride but not getting in and out
Old Dec 13, 2016 | 05:33 AM
plums's Avatar
Fuel pump on the way out .... real soon.
Old Dec 14, 2016 | 05:14 PM
bdboyle's Avatar
Funny...I was noticing a drop in fuel mileage, the occasional hard start...no codes, but nothing I could put my finger on.
One day, engine just cranked. Pulled out my fuel system pressure gauge and hooked up to the test valve on the fuel rails. Nothing.
Out came the tank. Checked voltages, relay, connections. Nada. Pump dead (and the in-tank harness connector at the pump end crumbled as I took it off.)
1 new fuel pump, 1 new filter, one new harness. Lots of grunting and swearing (the factory ran the harness for the rear left side marker BETWEEN the fuel filler neck and the overflow hose...so had to pull the harness back from the bumper...grrrr...must have been after lunch at the pub on a friday..). Gently disassembled all the fiddly plastic things (didn't break or snap anything...), put all back together...car fired right up. And, in the removal and replacement...seem to have solved a squeaking noise that came from the back whenever I hit a bump...like it when one job solves two issues...
Leaper's purring (well, had to replace a dodgy ignition coil today, but, that was a 20 minute job). Picking up the new XJR in a couple days...applied for classic (not antique) plates, since it's on classic insurance.
Old Dec 15, 2016 | 07:01 AM
JagV8's Avatar
Yayy, sounds good!
Old Dec 21, 2016 | 08:16 PM
Dicque's Avatar
Default Lean Banks 1 & 2
2002 VDP X308 lean banks 1&2.
First I looked at the fuel system, changed filter and did a system flush.
Thought I had it beaten until the jerking, misfiring, restricted performance and lean banks 1&2 started.
Thanks for the info on the lean banks 1 & 2. I'll start with vaccuume leaks, then the MAF sensor and finish up with plugs and see if any wires and or coils needs to be replaced.
Will get back in a few to give you the results
All the best!
Dicque
Old Dec 27, 2016 | 01:23 AM
Banned
Default Probinally solved
went down to my garage last night, was checking for any air leaks in the intake tube and other areas, none noted. Decided to remove the "beautification panels" to check for any breaks/leaks at the purge valve, and load and behold, somehow the electrical plug for the purge valve disconnected. plugged it in, cleared the codes, and all is running well.
Old Dec 27, 2016 | 01:41 AM
JagV8's Avatar
That'll do nicely!
Old Dec 27, 2016 | 03:23 AM
ericjansen's Avatar
Originally Posted by daverb
...plugged it in, cleared the codes, and all is running well.
Late Christmas gift, good news!
