Retrofiting newer stereo?
Old Nov 3, 2013 | 10:57 PM
Dpk2313's Avatar
Default Retrofiting newer stereo?
Is it possible to replace a 308 stereo and ac controls with a 350-358 stereo and ac controls?
Thank you,
Old Nov 3, 2013 | 11:41 PM
Zorasmiles's Avatar
Bump for a good question! I'd also like to know this answer for possible future mod.
Old Nov 5, 2013 | 06:18 AM
Dpk2313's Avatar
Bump
Old Nov 5, 2013 | 10:21 AM
luc's Avatar
luc
With enough time and money, everything is possible. Will be cheaper and faster to sell your car and buy the car that has the sound system that you want
Old Nov 5, 2013 | 12:02 PM
Zorasmiles's Avatar
DPK, Looks like you're going to have to take the plunge and see if it's possible. No one has chimed in after a few days. I was sure someone would have tried this mod but I was wrong.
You can pull your unit or a similar one and compare the plugs first and foremost. If the plugs are different, you'll have to figure out the use of each wire and if you can make it work.
Next check the fitting of the new unit in the old units area. From first glance it looks like an easy swap but nothing about these Jags are EASY as I'm learning lol
Good luck if you move forward, do a thorough write up, take plenty of pictures.
Chris
Old Nov 5, 2013 | 02:30 PM
Sean B's Avatar
No, copper cables = X308 fiber optic data = X35X you would have to transplant a whole lot more that just the head...I've taken a look at both w/d's and it's chalk and cheese.
Hope this saves you the trouble
Old Nov 6, 2013 | 02:03 PM
Dpk2313's Avatar
Can I buy/do they make a converter for the 308's?
Old Nov 6, 2013 | 10:25 PM
Zorasmiles's Avatar
Sean B, thanks for the confirmation that it won't work. I didn't think about the fiber optics change with the newer model. I guess using an aftermarket head unit with navigation and a custom face plate will be the way to go.
hoodun
Feb 20, 2023 05:52 AM
Presence
Mar 13, 2016 02:21 PM
Rocky15
Oct 12, 2015 03:42 AM
baskervillema
Oct 1, 2015 01:59 AM
