Rotten - Inner Sills to floor pan - investigating ?
Old May 1, 2021 | 02:25 AM
JamBar's Avatar
Hi
Sorry for bringing to life an old thread.
Did you manage to get all this welding done?
I have the same problem, but it seems to be only from the front of the inner sill to the B pillar and I have cut out an inch or 2 of the floor in order to patch a panel in. The thin middle sill (which seems to have circular holes in it has rusted at the bottom where it attaches to the inner sill which in turn has gone along the seam with the floor. The rest looks solid.
Did you find any diagrams of how it is supposed to look?
Did you do it yourself or was it all too much?
I have no ramp/.lift, so has to be done on the drive.
Like you I have probably put too much into this already and would rather spend hundreds more just to finish off.
James
Old May 1, 2021 | 02:30 AM
JamBar's Avatar
Hi again
I just read you did a lot of the prep yourself, the same position as I am now then.
Still cannot find diagrams though. Please let me know if you have photos etc, it may help me too :-)
Old May 1, 2021 | 04:53 AM
nurquhar's Avatar
Originally Posted by JamBar
Hi again
I did this job nearly 10 years ago now and the car is still on the road. Although there has been a bit more welding work since, Namely the other side on the subframe in the wheel arches just below the front shock mounts. When I started looking I found a number of areas that need some treatment. I end up rust treating and painting (POR-15) a number of areas under the car and I reinstated with some proper stone chip underseal (Not that bituminous fire hazard rubbish).
It was a biggish job as I choose to remove or protect most of the interior of the car to avoid fire risks and splattering nice stuff with angle grinder sparks. I managed with the car on axle stands and I did have some help with some of the welding. I probably had the car off the road a few weeks while I did this work and number of other jobs (Timing chains, ball joints, belts, houses etc). I have pictures still, here are a few:
Old May 1, 2021 | 07:26 AM
JamBar's Avatar
Great stuff. Thanks for posting the photos.
In your 2nd photo, it looks like the jacking point is not attached to the sill (same as mine currently). How should it be connected?
Also like the chassis rail repair. mine has started to go there, but on mine it seems maybe more rotten on the lower inside edge where the v mount sits.
I am not sure if it's weldable without dropping the subframe on my one.
Old May 1, 2021 | 07:56 AM
..... Also like the chassis rail repair. mine has started to go there, but on mine it seems maybe more rotten on the lower inside edge where the v mount sits.
James,
Your profile shows 1999 XK8. Is an X308 a change of / additional vehicle or are you looking for general welding repair advice?
Old May 1, 2021 | 02:12 PM
JamBar's Avatar
Hi
At present I have 3.
1999 XK8 all alive and well.
1999 XJ8 4.0 Sovereign - Needs welding and more- Ongoing.
2004 S Type R - Needs TPS/APP errors resolving - Ongoing.
Old May 4, 2021 | 02:27 PM
JamBar's Avatar
Just for info, I think that I have worked out what I need to do between these photos and the info on the video below.
The car in question in this video is an X300, but the same applies.
Old Mar 3, 2023 | 12:58 AM
  #28
asjdhsajhdfj's Avatar
Reviving an old thread..
I’m about to view an XJR but this one picture has me concerned. Is it a big job?
Old Mar 3, 2023 | 10:54 AM
earny's Avatar
You can only see the possible damage when the paint is off. I suspect it to be "only" superficial.
owendavis
Dec 15, 2023 07:40 AM
mlindblom
Jan 16, 2022 03:24 PM
XKR-DAY
Apr 23, 2021 11:11 PM
olivermarks
Apr 27, 2020 05:11 PM
sbreeden
Nov 17, 2012 11:02 AM
