Save an x308 from the Wreckers, won't run.
Old May 3, 2015 | 06:48 PM
ultraforce's Avatar
Default Save an x308 from the Wreckers, won't run.
I just bought a x308 and it won't run.
Throws up limp home mode and won't keep running.
Backfires out the intake manifold.
Any suggestion on where to start?
Old May 3, 2015 | 07:27 PM
cybercg's Avatar
It sounds like a timing issue.
Old May 3, 2015 | 07:28 PM
ultraforce's Avatar
I would guess there are 2 sensors for timing and both must be bad?
Old May 3, 2015 | 08:09 PM
motorcarman's Avatar
Did you remove the cam covers to check the timing chains????????????
bob gauff
Old May 3, 2015 | 08:24 PM
ultraforce's Avatar
bob gauff
No, but it has had a new timing chain and tensioners.
Old May 4, 2015 | 03:00 AM
andrew lowe's Avatar
Did they use the locking tool for setting the timing as a crankshaft holding tool?
It is known for the timing plate to distort and throw out the timing when this is done!
Old May 4, 2015 | 03:04 AM
ultraforce's Avatar
Chain was not done recently.
Did not hear any chain slapping.
I will check the chain but it could be electronic?
Does the chain issue cause a backfire in the Inlet manifold?
Old May 4, 2015 | 10:56 AM
Jhartz's Avatar
Sounds like a timing problem, which will cause backfiring -- plug fires when one or more intake valves are open.
Sure sounds like a jumped timing chain.
Old May 4, 2015 | 01:06 PM
dsnyder586's Avatar
1. Check cam timing
2. check compression
3. report back findings
adam699
Oct 13, 2015 05:53 PM
audibabba
Oct 4, 2015 05:41 PM
Delta66
Oct 4, 2015 05:40 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
