Seat automatic movement (back-forth)
Old Apr 23, 2022 | 09:38 PM
banar's Avatar
Default Seat automatic movement (back-forth)
I noticed that when I open the car, the seat doesn't automatically move back to create more space to enter (even though it's set to AUTO on the side of the steering wheel). Also, when I move the chair forward/back and then press one of the memory presets on the door (1, 2, or 3) it adjusts everything but the seat distance from the steering wheel (back/forward). Ideas?
Old Apr 23, 2022 | 09:45 PM
Addicted2boost's Avatar
I know it has to do with memory seat and your fob settings. I believe there’s more information in your owners manual addressing those exact concerns.
Old Apr 24, 2022 | 07:00 AM
Highhorse's Avatar
When you open the door, the seat should already be in the rearward position...as it should of gone back when you extracted the key before exiting. It will not go into a preset position until you put the key back in the ignition.
Now, a little more clarification, you state it accepts the memory setting, but doesn't give you distance from the wheel? So, is it not going back when you extract the key?
Old Apr 24, 2022 | 09:16 AM
motorcarman's Avatar
TSB for you!
File Type: pdf
File Type: pdf
e_brugal
Feb 26, 2021 01:34 PM
Smudge67
Jan 20, 2018 05:50 PM
user 2029223
Feb 1, 2010 12:25 PM
rgzx11
Jul 29, 2008 03:06 AM
CLOVERS
Oct 19, 2007 08:42 AM
