seat reversal
Old Dec 28, 2018 | 10:14 AM
billwyatt83's Avatar
Default seat reversal
Jaguar 308
Seat doesn't reverse when you remove ignition key, steering wheel reverses and tilts as it should
any ideas? Thanks.
Old Dec 28, 2018 | 12:27 PM
RJ237's Avatar
Try a hard reset. Disconnect the neg. cable from the battery and touch it to the positive for about 20 sec. Then reconnect, turn ignition on but don't start for 30 sec., then start car. It will have a fast idle initially but once it settles down reset the seat memory and see it it behaves.
Old Dec 28, 2018 | 01:15 PM
Thanks ill give your method a try, I have tried just removing the earth strap and leaving it for a while but that didn't work
I have also changed the seat module.
Old Dec 28, 2018 | 02:51 PM
RJ237's Avatar
I don't think the seat module controls the memory function since the wheel is also involved. I think the memory switch module connects to the door control module which then feeds to the seat control module, but I'm beyond the limit of my experience.
Old Dec 28, 2018 | 05:49 PM
ericjansen's Avatar
The seat and wheel are handled by 2 different modules, hence one working, and the other not.
Does your seat-memory (from the door operation push buttons) still work?
If the "hard reset" does not give results, then you might give swapping the seat modules a try (from driver side to passenger side and v.v.).
Should be doable with the seats inside the car by removing all 4 bolts, and flipping them.
If that doesn't work, it is probably (and most likely) related to broken potentio-meters in the seat, the ones controlling the various movements.
I just checked on all of mine, 4 out of 5 were broken off.
Old Dec 28, 2018 | 08:41 PM
motorcarman's Avatar
Did you set the column switch from AUTO to OFF????????????????????
I repaired DOZENS of seat position sensors (potentiometers) in new car warranty but very few 'customer-pay'.
The sensors are about $300 EACH and there are five. It also takes about 5 hours labor to replace them all so you are looking at about $2000 for the seat rebuild.
There are TSBs for diagnosing, replacement and testing/setup.
I have posted these DOZENS (hundreds?) of times in the past.
You need to read as many of these TSBs as you can find for your car and it will answer most of the questions people ask on this forum.
bob
File Type: pdf
File Type: pdf
Old Dec 28, 2018 | 10:10 PM
ericjansen's Avatar
If you are a bit handy, you can repair the potentiometers yourself, saving yourself the amount mentioned.
It is more work to get the sensors out and in, than the actual repair, a day's work for sure.
The cause of their failure is known (brittle plastic), and there are some 3 options to do the repair.
TreVoRTasmin
Aug 3, 2022 01:12 PM
Brandon Evans
Dec 23, 2018 10:52 AM
Fraser Mitchell
Dec 4, 2018 05:16 PM
dmchao
Dec 4, 2018 12:37 PM
Brandon Evans
Nov 30, 2018 05:53 PM
