security module question
Old Feb 9, 2010 | 03:09 PM
99txxjr's Avatar
Default security module question
so I have a bad security module on a 99 xjr lnc2600hd is the part number. I have found on the internet a 2003 xj8 that is being parted out but could not get the info from the guy if they have the same module. Just wondering if anyone knew offhand if the two share the same part number to save a 70 mile trip. thx in advance
Old Feb 9, 2010 | 08:54 PM
motorcarman's Avatar
You need to get the same last 3 digits from the VCATS (vehicle configuration and technical specifications) label in the boot from BOTH cars to match. Look in the boot near the spare wheel on your car for SLCM and record the part number and the /suffix and then ask the person who has the donar car to do the same. If they match you are good to go as far as compatatibility goes but you will need to configure the module to the vehicle. WDS,IDS or some other computer to configure the modules!! No guarantees if the numbers don't match.
good luck
bob gauff
Old Feb 10, 2010 | 11:09 AM
99txxjr's Avatar
thank you can I configure them myself or are those computers only available at the dealership?
Old Feb 10, 2010 | 09:43 PM
test point's Avatar
Haven't replaced the security module but the TCM and seat module were just plug-N-play.
Note the above comment about the extension (/xxx) being appropriate.
Old Feb 11, 2010 | 11:17 AM
Real_Tech's Avatar
Assuming you have matching VCATS numbers the only programming that will need to be done is the remote fob programming. The remote programming is stored in the SLCM. You can do this yourself, instructions are on this site.
Old Jun 18, 2012 | 03:48 PM
protech's Avatar
Question, module went bad part no. lje2600ab/001 talked to dealer and he suggested getting a newer unit with either ac, ag or af with a 008 no.
Any thoughts?
thanks
Old Jun 18, 2012 | 08:17 PM
sparkenzap's Avatar
The 99 XJR and the O2 XJ8 have different security modules. Its a long story but I am sure (I have both cars). The only difference I could identify is which fob works with the module. So, if you get the 99, get the fobs and I bet you will be OK. The late model numbers are harder to find.
St.Regis
Oct 4, 2024 12:07 PM
trosty
26
Dec 18, 2022 06:40 PM
XJsc-guy
Sep 25, 2015 11:09 AM
abonano
25
Sep 25, 2015 10:43 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
