Are shock mounts the same as shock bushings?
Old Dec 6, 2011 | 04:40 PM
SirJag's Avatar
Default Are shock mounts the same as shock bushings?
My mechanic first said I needed new shock bushings. Then, days later, said MOUNTS, which is more $$$. The shocks themselves are brand new. When they were installed, new bushings were not installed with them. The car's steering wheel pulls to one side or the other over bumps. Is this a bushing issue (which IS covered by my warranty) or a MOUNT issue (which is not)? Also, is the bushing job easier/less time consuming than the mount job? Thank you!
Mechanic quotes:
Front Shock Mounts 821.34
Tax 63.65
Labor 285.00
Total 1169.99
OUCH!
Old Dec 6, 2011 | 04:50 PM
test point's Avatar
The shock mounts are at the top of the shocks, the bushings at the bottom ends.
" . . . one side or the other . . . ." does indeed sound like a suspension problem subject to an inspection by a qualified technician. The shock is going to be out for a mount replacement so I would certainly have both ends done diagnosed or not.
Old Dec 6, 2011 | 07:29 PM
Sean B's Avatar
Something to be said for oem shocks...
The mounts are expensive, so the better option is to buy the upper mount bushing kit, they're pressed out and in. Jaguar only supply the mounts, hence the price. The kits can be found on the sponsors sites. Maybe get the rolebar bushes and track rods done while there.
An alignment to finish off, maybe a partial flush on the rack, and wheel balance. It should be transformed.
Old Dec 7, 2011 | 02:49 AM
SirJag's Avatar
Hey Sean,
So basically I need 2 bushings for each of the 2 front shocks, correct? Is the upper and lower bushing the same? I found them sold separately:
Amazon Part Finder: Slide Show Results
They look different although the description doesn't describe the difference.
Do I really need to spend $140 as I see on some sites like this:
Jaguar UPPER FRONT SHOCK MOUNT BUSHING KIT, DOES BOTH SIDES - MNC2168-69KIT
... which include washers and nuts. Must they be replaced, too?
Thanks so much!
SirJag
Old Dec 7, 2011 | 04:12 PM
XJRJeff's Avatar
I found this from another forum member on ebay. These are the front top shock mount bushings. The lower bushings are different.
Jaguar XJ8 Front Shock Replacement Bushings (4) | eBay
It includes 2 bushes for each side, 4 total.
Here is a link for the lower shock bushings, they are pretty inexpensive. However if you had the shocks replaced, they probably came with new bushings.
http://jaguar-parts.jagbits.com/search/index
Search for part number- MND2153AA
I would also check the ball joints. I just ordered and replaced my shock mount bushings to try to get rid of a bumping sound in the front and it turns out it is probably my ball joints. I tested them with the car off the ground with a pry bar under the tire and I reproduced the bumping sound, I am pretty sure it is coming from the ball joints. I am a bit disappointed though that the new ball joints I have found do not have grease fittings much like the originals. I am thinking about experimenting with adding a grease fitting and seeing if it helps to grease them up. The car only has 54K original miles, a little premature for ball joints to go. I just believe they have dried out from sitting the two years I had the car down for repairs. I will report back once I am able to add the fittings and grease them up.
Good luck to you.
Old Dec 8, 2011 | 03:34 AM
SirJag's Avatar
Good luck to you.
Thanks so much for the info. Please let me know how it goes!
SirJag
Old Dec 15, 2011 | 04:54 AM
SirJag's Avatar
Default New question about shock bushings...
Could someone please confirm that I simply need 4 of these:
http://www.amazon.com/OES-Genuine-Bu...ar=1&carId=001
... to replace my front shock bushings? (They're confirmed worn.)
I'm a bit thrown off because it says: "upper shock mounting stud"
Working on one side, say the right side, for example, I know one bushing goes on top of the shock mounting plate (it's clearly visible), but where does the other one go... on the under side of that same plate... or on the other end of the shock? I checked the JPEC and it doesn't show.
Thanks very much, guys!
SirJag
Old Dec 15, 2011 | 09:13 AM
dneider's Avatar
That does not look like the right item. I have an 01 vdp, I used a kit that contains four rubber washes (for lack of a better description). The shape appears different than what is shown in that picture. The kit I purchased cost about $ 80 or so, a bit expensive for what it is but it worked.
These are the right ones look at the difference in shape.
http://www.ebay.com/itm/Jaguar-XJ8-F...sories&vxp=mtr
Old Dec 15, 2011 | 05:22 PM
sparkenzap's Avatar
I believe the Amazon pictured ones look more like the stock bushings, although I have used the ones deneider referenced.
Old Dec 15, 2011 | 06:18 PM
dneider's Avatar
My oe brushing were made out of an Orange foam rubber material, and were a different shape...maybe the mount design changed at some point. While your in there you may want to consider replacing the bump stop (it also is used to hold the protective shock boot in place.)
Old May 8, 2012 | 03:55 PM
SirJag's Avatar
Default Do you need a press to remove the shock bushings (uppers)?
I have the mount off, but having a hard time separating the 2 bushings. Is a press needed... or are they threaded?
Thanks, all.
SirJag
Old May 8, 2012 | 04:07 PM
Sean B's Avatar
A press is the way - I understand the new bushes you can bang in with a hammer, did they come in black? I've seen the uprated version is a black neoprene type bush.
Old May 8, 2012 | 05:40 PM
OldMike's Avatar
Does anyone have a pictoral of this "press on/press off" procedure? I'm interested in trying this myself, but would like to see how it's done first. Thanks.
Old Jul 2, 2012 | 04:12 PM
thewired1's Avatar
I'd love some more info on the bushing installation procedure. I'm considering the kit but unsure if I have the right "press" to install it.
Poet
Feb 7, 2025 02:18 PM
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
ChrisJay
Sep 27, 2015 09:08 AM
