Shock replacement options
Old Aug 3, 2015 | 01:30 PM
SkinnyLard's Avatar
Default Shock replacement options
Hello everyone!
I have the chance to buy new rear shocks for my 98 XJ8 at half price. The only issue is that they are sport (green) bilstien shocks. I'm worried that they won't work very well with the comfort suspension.
I will be replacing the front shocks at the same time but I won't get the same deal. Should I go for it and put Sport shocks all the way around? Or should I mix comfort (black) bilstiens and sport (green) shocks. What's your opinions?
Old Aug 3, 2015 | 08:17 PM
Mark SF's Avatar
You should definitely do the fronts and rears, or not at all. I had the combination of comfort springs and sports shocks on my last XJ8. The ride is quite a bit stiffer and sportier, but not absurdly so.
It depends on how you like the ride now. If you think it's just right, stick with comfort shocks. If you would like it to be less floaty and more sporty, go for the green ones.
Old Aug 4, 2015 | 02:27 PM
rocklandjag's Avatar
I tried the sport shocks on the rear (and front) with my comfort springs and HATED the result. The rear became way to stiff. I took them off
Old Aug 5, 2015 | 07:03 AM
Jhartz's Avatar
I replaced the black Bilsteins with Greens on my 01 two years ago. Rides fine; didn't notice any change in handling.
Old Aug 6, 2015 | 08:03 AM
SkinnyLard's Avatar
I've decided to order a set of four black "comfort" bilstien shocks. I think it's weird that the comfort shocks are more expensive than the green "Sport" shocks.
Old Oct 1, 2015 | 10:43 AM
wcourt3010's Avatar
Hi, i apologise i know this thread is about two months old but can the original poster comment on their choice, whether they went green all way around or mixed them up or went with black all way around?
also can someone please post the bilstein part number for the black comfort shocks front and rear? i can find the green's easy enough of summitracing.com, between $100 and $123 each which is not bad.
Old Oct 1, 2015 | 10:53 AM
Bcrary3's Avatar
More Information for BILSTEIN 24023757
For the price though, I actually went with KYB, and am very happy with the results... It did take a little getting use to as they are stiffer than the OE comfort shocks (that had well over 100k mi on them). The fronts were really easy to replace, the rear required a lot more work... Personally I would go with the KYB Gas-A-Just. They add that slightly needed stiffness to the car, it rides beautifully, corners like a champ, and I imagine that that is how the car would have rode when brand new.
Old Oct 1, 2015 | 01:14 PM
wcourt3010's Avatar
thanks for the link. the bilstein blacks are about 50 bucks more than the green on summit.
Forcedair1
Sep 8, 2025 01:57 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
