Should the non-drivers window switches light up at night?
Old Jan 10, 2015 | 12:37 AM
Mark SF's Avatar
Default Should the non-drivers window switches light up at night?
The switch pack on the drivers armrest lights up fine with lights and ignition on. But the window switches on the other 3 doors do not. Is this normal?
I wouldn't normally care, but I've been fixing dash lighting, and replaced the bulbs in the shifter and cruise / sport buttons, as they had all blown, so now it's a case of while I'm at it....
Old Jan 10, 2015 | 02:15 AM
Gippsland's Avatar
Mine light up when driving at night if that helps Mark.
Old Apr 19, 2018 | 05:02 AM
King Charles's Avatar
Ok I have the OEM bulbs but my search to get to the passengers' door switch bulbs has not produced.
Can I get to them without removing the whole door panel, like maybe just prying up the wood trim & going from there ?!
Old Apr 19, 2018 | 08:09 AM
xjr2014_de's Avatar
Hi,
Yes, all of the window switches should light up. You can't remove them without removing the whole door panel, as the trim is screwed to the door card.
Furthermore you can't buy the bulbs off the Jaguar shelf (like e.g. for the climate control panel or instrument pack). I'll post some pics and details later the day.
Old Apr 19, 2018 | 08:49 AM
xjr2014_de's Avatar
Here we go!
You need to pull the the black rectangular rubber socket with the bulb off its two spikes. Then you'll have to unwrap the wires of the bulb and carefully remove the blue cover off the bulb, so that you can re-use it for the new bulb.
As replacement you can use T1 socket bulbs (12V) with long wires as shown in the picture. All bulbs with 0.35 - 0.5 Watt should work - in my opinion 0.4 W is a reasonable compromise between heat and brightness.
Old Apr 19, 2018 | 05:15 PM
The DBC6244 bulbs I bought from Jaguar are already blue so no need for the caps.
https://www.jagbits.com/product/DBC6244.html
99xk8guy
Sep 29, 2025 10:51 PM
D.K
Dec 10, 2023 02:05 AM
GordoCatCar
Jan 2, 2017 01:10 PM
redrover41
23
Sep 25, 2015 01:33 PM
laserguy
Sep 3, 2015 02:02 PM
