Side mouldings/bump strips/rubbing strips removal?
Old Jun 13, 2017 | 05:34 AM
Raghes98's Avatar
Default Side mouldings/bump strips/rubbing strips removal?
Thinking of trying to remove the side mouldings from my xj8 and was just wondering if there just stuck on or are there clips underneath aswell? Thanks
Old Jun 13, 2017 | 05:50 AM
Highhorse's Avatar
Welcome Raghes98, please take the time to introduce yourself in the New Members Area https://www.jaguarforums.com/forum/n...-intro-must-5/ ...please be sure to always list your vehicle or more simply, put it in your signature with details about it. We hope you find lots of useful information here and are able to help out others as well...cheers.
Old Jun 13, 2017 | 06:53 AM
convincor's Avatar
They use a two sided adhesive tape.
Manual says a heat gun.
Tape both sides to protect paint.
Apply local heat at one end and using a suitable thin lever progressively ease molding away from body.
Clean surface with white spirit.
Old Jun 13, 2017 | 02:44 PM
Stu 1986's Avatar
The XJR100 came out the factory without the rubbing strips on the door, it does make the car look sleeker. I've removed them on my XJ Sport, and I'm very pleased with the results. Be aware though that there may be a difference in paint colour underneath the strips where it's not been exposed to the sun. To remove them I used a heat gun and a plastic trim tool covered with a cotton cloth to prise and ease the strips off the car.
Attached Thumbnails Side mouldings/bump strips/rubbing strips removal?-strips.jpg
Old Jun 13, 2017 | 03:21 PM
Daim's Avatar
Exactly that, what I was going to do... Remove those lumps and leave that fancy XJ40 crease visible
Old Jun 17, 2017 | 08:12 AM
Dan Hiatt's Avatar
I have removed mine, and it does result in a cleaner look from the side. It took some elbow grease to remove all of the double sided tape that has been stuck to the car for the past 17 years. Now, about the darn weld/jack points visible underneath the car....
Old Jun 17, 2017 | 11:03 AM
Daim's Avatar
I thought of cutting them off and welsing the eariler style studs to the underneath instead.
Old Jun 17, 2017 | 12:26 PM
al_roethlisberger's Avatar
I've been planning on running a stainless steel piece along the bottom of the rocker from front to rear wheel about an inch wide that will mount to and cover the the underbody hem, partially cover the jack points and add some nice finished interest along the bottom of the car.
They can be made by someone like Stainless Supply for about $100 per side.
I haven't gotten around to it yet, but it's an easy modification. Once I do, I'll post some photos, etc.
Old Jun 19, 2017 | 02:07 PM
iwillfixit's Avatar
that looks great! Lucky i saw this before i bring the car to the body shop!
