Slight miss at 55MPH
Old May 4, 2009 | 09:53 AM
Keltam's Avatar
Default Slight miss at 55MPH
Sometimes I get a very slight miss, almost undetectable, when I run at around 55MPH. Anyone get this as wekll or am I being too picky. Just cleaned the MAF, throttle body, and part load breather. Didn't help
Old May 5, 2009 | 09:38 AM
wazari's Avatar
A miss can also be electrical. Valve gaskets have a tendency to start leaking on these cars which causes oil to go into the spark plug wells. This can cause a miss. Pull the ignition coils to see if you have oil in the wells. You might have a bad plug also.
Old May 5, 2009 | 02:17 PM
Keltam's Avatar
Thanks-sounds like a good Saturday job. I'll post back my reults.
Old May 8, 2009 | 02:28 AM
sparkenzap's Avatar
Just a hunch- that is about the speed of the torque converter lock up. Might that be what you are feeling?
Old May 11, 2009 | 08:29 PM
Keltam's Avatar
Mine seems to happen between 55-60 MPH. If I hold the car steady at that speed it will surge a small amount. Over 60 and smooth as glass. I've cleaned the TB, MAF, fuel filter, part load breather-I gues next are the plugs and coils. Anyway to inspect the coils without just puting in new??
Old May 17, 2009 | 11:43 AM
jag_genius's Avatar
Ossilations in the trani at that speed can be what you guys are feeling .. Software update thru coded access for the tran is available .
Old May 17, 2009 | 08:34 PM
Keltam's Avatar
Thnaks-what do I ask the dealer to do? Is this common?
MrWhite
19
Jun 14, 2022 07:49 PM
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
Inspector
Oct 17, 2015 12:51 PM
vwbusbits
Oct 13, 2015 03:43 AM
42Ajd
Sep 26, 2015 07:04 PM
