Slightly low coolant
Old Jul 5, 2011 | 10:25 PM
bhamilton2790's Avatar
Default Sunroof won't close completely
I am a new member and have just purchased my first jaguar. It is a 1998 XJ8 and needs a little work. The first project I took on was replacing the cab to the drivers front door handle. Unfortunately I think I messed up the sunroof when I fixed the door handle. As I was removing the latch mechanism I pulled it down to clear the window channel. I heard a click and noticed the sunroof had opened about an inch. After I got it back together the sunroof will not close all the way. It stays about 1/2 way open. I can use the button to close it but it will only stay closed a few seconds and then go back to the 1/2 open position. I have read about the synch operation on newer X type and am hoping there is one for XJ. Any help would be greatly appreciated.
Old Jul 5, 2011 | 10:42 PM
Scottish Chap's Avatar
Default Addtional info...
I learned today that the prior owner knew about a faulty thermostat and cracked thermostat housing right before the car was sold to me. Both were replaced before I received the car. I was also told that the addition of coolant into the system was not as detailed above, and so a technician with Jaguar experience is now taking a look. I wonder if there was a technical problem with the installation of the afore-mentioned hardware? Again, I have a hard time believing that this much coolant could be lost merely from 'standard' addition of coolant. I will keep you posted. Many thanks.
Old Jul 6, 2011 | 06:01 AM
jimlombardi's Avatar
Hi bhamilton2790
Welcome to this forum.
There are existing threads that cover fixing/adjusting the Sunroof.
Here are links to 3 of these sunroof issues and how to fix them:
1998 XJ8 Sunroof Problem https://www.jaguarforums.com/forum/jaguar-xj8-jaguar-xjr-27/1998-xj8-sunroof-problem-56011/
XJR Sunroof https://www.jaguarforums.com/forum/jaguar-xj8-jaguar-xjr-27/xjr-sunroof-55344/
Self Closing Sunroof https://www.jaguarforums.com/forum/j...sunroof-52265/
Your best chance of finding information about a problem you are having with Jaguar is to use the forum search.
I just found these 3 threads and other threads by using the search words "Sun Roof" here in the XJ8 & XJR forum.
Also this Sun Roof posting should not have been posted in this Low Coolant thread.
I am not trying to be critical, I am just trying to advise you on how to post and find information on the forum.
I hope this information helps.
Jim Lombardi
Old Jul 6, 2011 | 09:21 AM
Thanks JIm for the information. I am new to this and am still trying to figure out how to get to certain forums. This site has been great for all types of information and everyone has been really understanding of the newbies.
Old Jul 6, 2011 | 11:52 AM
Agreed!
scooternva
19
Oct 27, 2015 02:14 PM
OkieTim
Sep 8, 2015 04:48 PM
1100me
Sep 7, 2015 06:26 AM
giandanielxk8
Sep 6, 2015 07:21 PM
OkieTim
Sep 2, 2015 12:48 PM
