Smells Hot
Old Sep 13, 2011 | 07:15 PM
The Rand Man's Avatar
Question Smells Hot
And yet it's not. I flushed the coolant and replaced it a month ago, after putting in a new water pump and thermostat. It doesn't run hot--after it warms up, the temp gauge doesn't budge off from midway, even on hot days--and there are no visible leaks, as well as no change in coolant level. Any ideas?
Old Sep 13, 2011 | 11:06 PM
pdog2000's Avatar
the temp gauge is setup to read in the middle for a big range of temps so you cant go by that...get a cheap laser thermometer and read the engine block temp...you can get an idea of whats going on...
Old Sep 14, 2011 | 05:53 AM
test point's Avatar
Doesn't smell like a drop or two of coolant on one of the cats does it?
Common problem is a very slow leak from the coolant reservoir or Norma connectors on the heater hoses onto the cat. Never a drop on the floor.
Old Sep 14, 2011 | 09:02 AM
JimmyL's Avatar
Second on the temp gauge. I had a hose blow off and the idiot light came on before the temp gauge showed anything over mid-way.
Old Sep 14, 2011 | 11:41 AM
Could be. I'll take a look--what are Norma connectors, by the way?
Old Sep 14, 2011 | 02:41 PM
test point's Avatar
There are 'Norma' connectors in the climate control coolant lines on each side of the engine. They connect the engine hoses to the body hoses for initial assembly. They are plastic snap together connectors sealed with an 'O' ring much like a garden hose quick connect.
Prone to a small drip leak after 10 years or so. The 'O' ring is replaceable if you can get the connectors apart without destroying them. Some have cut them out and replaced with 5/8" heater hose and clamps.
NORMA Group - Connectors - Quick Connectors - NORMA Quick PS3
Old Sep 14, 2011 | 03:32 PM
plums's Avatar
Fast (dis-) assembly without tools = time and cost savings
definition of a bald faced lie.
Old Sep 14, 2011 | 09:23 PM
Temp gauge works fine, but thanks for the suggestions on that. I'll look over my Norma connections and such to see if I can find the culprit; that would seem a real possibility. Plums, you must not like those connectors, huh?
NathanDD6
Oct 6, 2015 11:20 AM
mat32essex
Oct 3, 2015 04:12 PM
inactualis
Oct 2, 2015 11:13 AM
rgp
Oct 1, 2015 02:55 AM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
