So today I find out I need to spend $140 just to check my tire air pressure
Old Aug 19, 2012 | 05:51 PM
Originally Posted by jaguars4r
If I take that screw off, will the air come out right away?
NO - the cap conceals the recessed valve. You will not lose air by removing the cap.
To inflate the tyre, you need to screw in a valve extension:
This is on my Sepang but other split rims are similar.
Attached Thumbnails So today I find out I need to spend 0 just to check my tire air pressure-dsc_0074.jpg
Old Dec 8, 2013 | 09:11 AM
DJ-Roy's Avatar
Originally Posted by DJ-Roy
Sadly Replacement wheel rings are not available in 19" for the XJR100 BBS wheels, only 18" and 20".
Just got noticed the 19inch trim rings are available from SB Wheels
they do 18, 19 and 20inch
- www.sbwheels.co.uk
Old May 24, 2014 | 03:13 PM
newXKRguy's Avatar
Default BBS valve stem adapters and valve stem caps
Originally Posted by GGG
NO - the cap conceals the recessed valve. You will not lose air by removing the cap. . . To inflate the tyre, you need to screw in a valve extension. . .Graham
Even though I have the complete original leather pouch kit with the two valve extensions and one spare valve cap, I just picked up 4 each of the caps and extensions because it seems they are becoming scarce. I found original BBS parts on eBay by searching for BBS valve stem adapters and BBS valve stem caps.
Rgds, Fred
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
philwarner
Dec 6, 2021 07:13 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
cheaperts
Aug 30, 2015 06:48 PM
