"Stability Control Fail"-What and Why?
Old Feb 22, 2009 | 09:40 PM
wjgesq's Avatar
Default "Stability Control Fail"-What and Why?
98 XJ8, 75K miles. Runs great. New steering pump, wheel bearings, oil change and brakes in the last 4K. Suddenly, the "stability control fail" warning comes on in the speedometer display. ABS light comes on too. Not sure if there is any connection between the two. Both appear to have come on at the same time about a week ago after a normal drive. Car sat for a week, yet the lights still come on. No other problems and it runs just fine.
What causes this and is it a real issue or some software glitch? Any ideas or information appreciated.
Old Feb 23, 2009 | 06:07 PM
jag_genius's Avatar
they are related .. make sure your battery is good.. weak battery's can give a abs dsc light on when cranking.. you will need to check codes my guess is c1095
Old Feb 23, 2009 | 06:35 PM
SuperSport's Avatar
Is it possible that a wheel sensor was bumped or wire accidentially cut during the brake job?
Just a thought, as I had this problem with another vehicle. Wire had been cut.
Old Feb 28, 2009 | 06:35 AM
jaggachafen's Avatar
It´s often a failde heab ABS unit they werent to good on the 98 think you can buy remanufactured ones . But ofcourse you will need to check it out first.
leep123
Sep 30, 2015 03:41 PM
mrplow58
Sep 30, 2015 08:56 AM
Blake04VDP
Sep 28, 2015 05:20 PM
zdrapec
Sep 25, 2015 05:49 AM
