stability control fault on screen
Old Jan 31, 2012 | 02:21 PM
lostpinky's Avatar
Default stability control fault on screen
The little information panel is flashing "stability control faulty". Where do I start???
Old Jan 31, 2012 | 02:28 PM
JimmyL's Avatar
Make sure your grounds and battery connections are good and clean. Make sure the battery is up to snuff. Try dsconnecting the battery and/or doing a reset.
Old Jan 31, 2012 | 08:57 PM
motorcarman's Avatar
What DTC is logged in the ECM and/or ABS modules?????????????????
bob gauff
Old Jan 31, 2012 | 09:39 PM
Gus's Avatar
Gus
When is it flashing and what are you doing when it takes place? Is the car moving? The question was asked about codes do you have any? Along with all of this do you know the year and model of your car? Please post it.
Old Feb 1, 2012 | 11:47 AM
lostpinky's Avatar
Default thanks for everyones help
I will clean the battery terminals.
The message comes up as soon as you start the car and stays on all the time.
I have not checked for trouble codes yet.
Old Feb 1, 2012 | 12:15 PM
Gus's Avatar
Gus
Reading the codes is the right thing to do. The cause could be many things from cleaning the sensors & connectors to poor connection at the ABS control. Read the codes first if you can.
Old Feb 1, 2012 | 12:36 PM
Sean B's Avatar
how old is the battery - this fault can flag if it's not in the best shape.
trosty
26
Dec 18, 2022 06:40 PM
captbob73
Oct 24, 2015 05:49 PM
jhn
Sep 21, 2015 09:43 PM
texaspete
Sep 10, 2015 08:34 AM
tberg
Sep 7, 2015 07:32 AM
