Stability Traction Control & ABS Light
Old Nov 16, 2014 | 09:28 PM
sitework's Avatar
Default Stability Traction Control & ABS Light
Stability Control Failure light goes on with ABS light after driving a while 1/2 hr but varies. Goes off resets when restart.
Any suggestions on this. Cleaned sensors already.
Old Nov 17, 2014 | 03:46 AM
JagV8's Avatar
Maybe a sensor problem but could be a wheel bearing that's allowing more movement than it ought (i.e. is failing). Read ABS codes.
Old Nov 17, 2014 | 04:08 AM
Welcome to the forum sitework,
I've moved your question from General Tech Help to X308 forum. This is the place to post tech questions about your model.
Old Nov 18, 2014 | 04:30 PM
sitework's Avatar
Thank you. Codes did not pick up any code history.
Old Nov 18, 2014 | 06:40 PM
RJ237's Avatar
Many code readers do not pick up Jag ABS codes.
Old Nov 19, 2014 | 07:49 AM
JimmyL's Avatar
Sometimes a low battery will cause this, but that would show up right on start up not after a half and hour of driving. It could be the cold solder problem with the ABS module. A lot of people have had that issue including me. Try a search on "ABS module solder" or something similar.
Old Nov 19, 2014 | 08:19 AM
vincekal's Avatar
I had the same issue. Couldn't track it until I had a reader on the car when the light was on.
Old Nov 19, 2014 | 08:31 AM
aode06's Avatar
https://www.jaguarforums.com/forum/x...-sheet-131461/
H20boy
Dec 24, 2024 03:23 PM
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
pocketrocket
Sep 3, 2015 07:44 PM
innzane
Sep 2, 2015 10:08 AM
