Start of Steel liners
Old Dec 11, 2017 | 01:48 AM
Heliwilly's Avatar
Default Start of Steel liners
I know there was an engine number from which steel liners replaced the Nikasil ones, in the X308, due to them failing under high sulphur in the petrol. 180801 seems to come to mind?? Was there a change in the VIN to indicate the steel liners were fitted.
Thanks Bill W.
Old Dec 11, 2017 | 02:21 AM
JagV8's Avatar
No. You need to check the actual engine #.
Well, eventually the VIN would be safe to check but it would be say a year later.
Also, if the car has nikasil then a simple test will show if it has problems and if it hasn't then arguably it's better than a non-nikasil car.
Old Dec 11, 2017 | 05:52 AM
Heliwilly's Avatar
I was asking on behalf of someone who has a 1998 XJR and wanted to know if he had a Nikasil lined engine. My reply was, if it has been OK since you bought it you will be OK, as sulphur content is now greatly reduced. Bill W.
Old Dec 11, 2017 | 11:18 AM
motorcarman's Avatar
Severe engine overtemp will also destroy the lining in the cylinders!!!!!!!
bob
Old Dec 11, 2017 | 08:01 PM
RJ237's Avatar
Bob's comment is extremely important. I suggest to all the nikasil owners I meet to install the Realgauge mod or at least use a Ultragauge, both of which have audible temperature alarms.
bt965
Jun 15, 2011 11:14 PM
misskitty
Aug 12, 2010 03:21 PM
GordoCatCar
Mar 9, 2008 10:08 PM
IronCobra
May 14, 2007 05:07 PM
