starter problem
Old Oct 16, 2012 | 02:15 PM
gieniukas's Avatar
Default starter problem
starter in 2000 XJ8 doing click and finish , ive check battery is good, and now i must change starter, maybe anyone do this and can say how ?
Old Oct 17, 2012 | 05:40 AM
Sean B's Avatar
The process of swapping the starter out is detailed in JTIS available to download here,
https://www.jaguarforums.com/forum/x...archive-65998/
or pdf manual here,
https://www.jaguarforums.com/forum/x...at-x308-81022/
Before changing I'd certainly check a few power points first,
The black high power cables and their connections that run along the inside of the front fenders or wings, lift the bonnet and locate them - one terminates on a brass bolt on the brake servo cover, the other runs to the fuse boxes on the other side. Check their terminals and clean them up.
The earth strap between the engine and body underneath the car, and the earth terminal in the boot. Also the Mega fuse terminals behind the spare wheel can get bumped if the spare isn't tied down.
1964Daimler
Sep 9, 2015 11:28 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
TC Johnson
Sep 2, 2015 09:30 AM
