starter problem?
Old Oct 28, 2012 | 12:16 PM
gieniukas's Avatar
Default starter problem?
when i turn key in ignition i hear click and .. finish, i took out starter i ve got used one but i go to check and my old and that used working perfectly , what i must check and where i must looking for to fix this problem?
Old Oct 28, 2012 | 12:30 PM
danielsand's Avatar
Check your battery first.
Old Oct 28, 2012 | 01:26 PM
gieniukas's Avatar
ive check- perfect, like freaking new, what else i can check?
Old Oct 28, 2012 | 02:12 PM
Highlander64's Avatar
This sounds like the exciter ring issue... turn the key, and no crank/no start.
You'll find the exciter ring is the black plastic circle around the key switch on the column. Up inside the column (above the speaker for the warning chimes, turn signal noise, etc.) is a white plastic plug which has the two wires for the exciter. Disconnect the plug and check for 33.4Ω (or close to it) through that coil.
15 minutes tops to drop the lower column shroud (two philips screws) pop the plug, check the resistance, and pop to column back together it it checks OK. The ease of checking this should make it one of the first items in a diagnostic process.
Attached Thumbnails starter problem?-column-key-side.jpg   starter problem?-exciter-plug-1.jpg   starter problem?-exciter-plug-2.jpg
Old Oct 28, 2012 | 02:46 PM
gieniukas's Avatar
thanks going to do will see
Old Oct 29, 2012 | 09:00 PM
motorcarman's Avatar
Sounds like the melted cable connector on the false bulkhead.
Bad connection and not enough power to the starter!!!!
bob gauff
1964Daimler
Sep 9, 2015 11:28 AM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
TC Johnson
Sep 2, 2015 09:30 AM
