Steering wheel volume buttons on the fritz
Old Mar 15, 2018 | 05:40 PM
poisonpill's Avatar
Default Steering wheel volume buttons on the fritz
Has anybody experienced issues with the x308 steering wheel buttons? My volume up button works only intermittently at best. Often it doesn't work at all. The volume down button is fine. Any repair advice? Thanks!
Old Mar 15, 2018 | 08:01 PM
RJ237's Avatar
Any problem with cruise control? My 97 XK8 had a intermittent cc problem which I finally traced to a bad ground wire connection in the volume control. The cc ground connects to the volume ground. Anyway, I would take a look at the wiring in the steering wheel.
Old Mar 16, 2018 | 02:06 AM
Lady Penelope's Avatar
There is a ribbon cable in the steering column called a ? it can be repaired yourself or replaced at a higher cost
Old Mar 16, 2018 | 06:47 AM
RJ237's Avatar
Yes, the clockspring. The manual has trouble shooting procedures to identify faulty components and circuits.
cbornet
Apr 20, 2014 05:13 PM
Catsgame
21
Apr 1, 2014 02:34 PM
Lothar52
Mar 22, 2014 03:22 PM
Wolfie84
Aug 5, 2011 06:22 PM
fritz
Jul 27, 2011 10:14 AM
