Stuck in park
Old Aug 14, 2019 | 06:25 PM
Highhorse's Avatar
Hey Bob, if he hasn't cleared the codes, ..will he still be receiving them then?
Next, have you cleared the codes AltonJag?
For your instrument pack, double check your connectors, as stated, if they're not properly seated, they won't work.
Old Aug 14, 2019 | 08:20 PM
motorcarman's Avatar
If the INSTPK has failed and compromised the CAN bus, then clearing the DTCs is irrelevant.(they will not clear if it is a HARD FAULT)
The INSTPK is the gateway to the networks.
bob
Old Aug 15, 2019 | 08:42 AM
AltonJag's Avatar
I don't know the code clearing process
Old Aug 15, 2019 | 09:08 AM
The DTC's are read and cleared using an OBDII 'scan-tool'.
Attempting to diagnose and repair without one is going to get very difficult and time consuming.
The best tool for looking at ALL the modules on the CAN bus is WDS, IDS or similar.
A generic 'scan-tool' will at least read the ECM.
bob
Old Nov 7, 2020 | 11:50 AM
Bob Cutlip's Avatar
With so many lights, error messages it may be a weak battery or connections. My 'Locked in the park and no brake lights' were due to a broken wire at the brake switch connector. I probably did that by replacing the switch.
giandanielxk8
Jan 23, 2018 05:35 PM
anthawk
Jan 28, 2017 04:29 PM
doc
Nov 24, 2014 05:47 AM
jaguar lover
US Central
May 12, 2013 09:12 PM
The Craig's
17
Jan 13, 2012 02:45 AM
