Stupid question - XJ8 to XJR conversion
Old Jun 18, 2013 | 02:46 AM
MoscowLeaper's Avatar
Default Stupid question - XJ8 to XJR conversion
Hi, guys
I'm feeling lack of perfomance with a XJ8, but there's no XJR's in a good condition available on the market. Import of the XJR is almost impossible.
So - 2 options here:
1. Get a swap kit from jaguarspecialities and implant LS-series engine. Good engine, with lots of power. But it will be a modded car with a alien powertrain.
2. Get an XJR donor with a rotted body and bad interior and swap everything into mine XJ8 (during the swap process i can also rebuild a suspension, tensioners and so on).
On a second route - i suppose that i should swap:
-engine and tranny
-ECM and TCM
-Instrument cluster
-Engine wiring
-Intercooler pump
-Fuel tank with fuel pumps
Anything else i've forgot to mention (like exhaust, under-dash wiring, other electronic modules, driveshaft and so so)?
Thanks so much
Old Jun 18, 2013 | 07:20 AM
Sean B's Avatar
whatever route you decide, it's a big job for a car of low value.
I rebuilt one from the ground up into a new shell and know it's not an easy or fast job. There'll be things you'll come across that set you back. Even in the UK I found some parts hard to find. A donor is the best option as all the modules wiring harnesses etc will be the least problematic.
Old Jun 18, 2013 | 07:29 AM
The value of this car is not so low in Russia.
I've rebuild this car too -
new engine (swapped by myself)
rebuilt transmission (did it by myself)
rebuilt suspension (frt. and rr - by myself)
and so on. Body is in a perfect condition.
That's why i'm considering only a parts car for XJR conversion. But there's no need in a donor car for a LS conversion.
And, speaking about a conversion to an XJR, i'm wondering if i'll need to change the underdash wiring and other things, that will require too much disassebly procedures.
Old Jun 18, 2013 | 08:59 AM
Sean B's Avatar
Yes, S/C and non S/C dash looms, power columns, IPK, BCM etc etc are all different.
Why not just buy an R? There must be a few in Germany/France/Netherlands/etc?
Old Jun 18, 2013 | 09:07 AM
Ouch, that hurts. Then it's better to go a LS way...
I must pay approx.35000$ of customs fees to get the russian title for the european/american XJR No way.
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
luc891
XE ( X760 )
Sep 15, 2015 12:30 AM
philwarner
Sep 6, 2015 11:10 PM
