Successful timing chain replacement... maybe?
Old Nov 26, 2020 | 08:03 AM
hispeed42's Avatar
Hmmm, guess I didn't remember correctly; it was 12 years ago when I did mine.
Old Nov 26, 2020 | 10:12 AM
Carnival Kid's Avatar
If I remember correctly the forward of the two sprockets has a center-punch "timing mark" on it. This indicates that it is the forward of the two sprockets, and this center-punch mark should to the front and visible to the assembler. The rear sprocket does not have a center-punch "timing mark" and should be fitted behind the front sprocket, closest to the crankshaft journals, in an offset condition ensuring that the teeth of the forward and rear sprockets are offset. If the teeth are not offset, simply remove the rear sprocket and flip it over.
xjrjag
Nov 27, 2025 09:16 AM
Kroeger’s Jag
Nov 11, 2020 07:39 AM
Andreas Schmieg
May 16, 2017 10:44 AM
ricardo
Mar 18, 2011 01:37 PM
Sparkers69
Oct 13, 2008 02:53 PM
