Suspension Fault
Old Sep 6, 2009 | 10:45 AM
johnleavitt's Avatar
Default Suspension Fault
2003 xjr running fine with no problems. Suspension Fault shown in the odometer display.
A week ago I found packrat damage to left headlight wiring after I got a trac control, stability control message. After I repaired the damaged wiring, the message went away. I did a pretty solid search for additional wiring damage at the time.
I have a crappy acutron code reader that shows no codes. Occaisionally I get a code for the fuel level sensor, but all of my European cars have a problem measuring gas levels lately.
Anyone know what trips the Suspension Fault code?
Old Sep 7, 2009 | 04:33 PM
roviw's Avatar
try the other thread for the newer XJ350 series, I have posted on there and the UK site as well, you will see it is a common problem on the earlier cars from 2003 and 2004, nomally the compressor or shocks.
Old Sep 9, 2009 | 08:40 AM
does anybody know which relay or fuse may be involved with the ADS system?
Old Sep 13, 2009 | 12:58 AM
Ok, so if I respond to my own post, it goes to the top again and has another opportunity to be read.....
any ideas?
Old Dec 10, 2009 | 10:41 AM
My car does not have an air suspension, but has a variable valve that is controlled by a computer mounted on the "bulkhead," from what I hear. The computer gets data from two accelerometers, front to rear motion and side to side motion, and makes a decision about whether or not to stiffen the suspension. If it decides that I am driving agressively enough, it stops appling five volts to each wire that feeds the top of the shocks, causing an internal valve to constrict the fluid exchange, and firm up the shock and ride. So, absent the voltage to the shock, the shock is in extreme performance (buckboard) mode.
I would really appreciate any information about where I can look for an abraded wire, or something like that, that is causing this fault. Also, where is that little computer...
Old Dec 10, 2009 | 02:17 PM
H20boy's Avatar
Ahh, sounds like CATS system them. Not sure about the specifics, XJRs and XKRs have them, but again...not familiar. Try a search again using CATS and see what you can find. Maybe add to an existing thread for more help. good luck John.
Old Dec 12, 2009 | 02:54 AM
janbache's Avatar
I had a loose connection between the sensor and shock on my XJR, that caused the "suspension fault" error to show.
To rectify it I just removed the black plastic protector thingie in the engine bay removed the connector and reattached it.
Old Jan 20, 2010 | 10:34 AM
Problem solved...I am living the dream....it was packrat damage to the wires coming off the top of the left rear shock. Car rides nice again.
Old Jan 20, 2010 | 01:57 PM
H20boy's Avatar
Yeah! attaboy john, buy yourself a beer on me
Old Jan 21, 2010 | 02:14 PM
H20boy's Avatar
random post 4pedro, but it contributed absolutely nothing to this thread, nor debated anything within it. I almost deleted it.
Since you mentioned it, yes dealers have higher parts prices than say any other supplier, but they also support the dealership's overhead and generate revenue for the dealer. I'd say I buy 50/50 dealer vs internet source. Each situation is going to be different and can't be blanketed with the 'I'll never buy parts from a dealer again'. To do so is just silly.
Old Jan 22, 2010 | 05:19 PM
Default I patronize my dealer's parts counter
They guy that works there knows a little about the parts, and has been very helpful to me. Also, when you need the right part the first time, like with all the different variations in pulleys, there is no substitute for the dealer. My experience has been that on many items I save nothing on the net. I would bet I buy 50-50 as well, and have been doing that with Jaguars since 1984.
MrWhite
19
Jun 14, 2022 07:49 PM
magmedia
Aug 15, 2019 08:54 PM
leep123
Sep 30, 2015 03:41 PM
ChrisJay
Sep 27, 2015 09:08 AM
driver safz
Sep 26, 2015 06:01 AM
