Switchs bulbs troubles - XJ308
Old Feb 13, 2016 | 12:43 PM
glouglou's Avatar
Default Switchs bulbs troubles - XJ308
Hi !
I have changed the bulbs of both the fog lamp and trip computer switchs of my XJ308. I thought they were dead. Note: the switchs are operating well even if the bulbs are out.
Now, the new bulbs have been mounted but are still not working when I switch on the lights.
Remarks: at the same time the lightings of the cruise control and gearbox sport mode switchs are out while the main beam is on (as if the two bubs are blown as well).
Somebody knows what should be the trouble ?
Thank you !
Old Feb 13, 2016 | 02:10 PM
Bcrary3's Avatar
To clarify, the fog lamps (front?) are not operating with the switch with new bulbs?
Old Feb 13, 2016 | 08:15 PM
Jhartz's Avatar
Guessing you have a broken wire/solder in the multi-purpose switch.
Old Feb 13, 2016 | 08:43 PM
andrew lowe's Avatar
I think something may have been lost in translation here.
The front fog lamps will only work if the side lights (parking lights) or dipped beam headlamps are on!
The front fog lamps should go out when main beam (brights) are activated!
I know this is UK law, so I assume (I know that is only making an *** out of U and ME) that it is a Euro wide lighting law, as we are all ruled by those unelected ******** in Brussels.
Old Feb 14, 2016 | 04:41 AM
glouglou's Avatar
Thank you for your answer Bcrary3,
The fog lamps (front & rear) are operating when the switchs are on (leds OK). But at night, with the main beam is on, the miniature light "blue" bulbs which should enlighten the switch are still off... the same for the other switchs (trip computer, cruise control and gearbox sport mode switchs).
Nick
Old Feb 14, 2016 | 05:05 AM
Daim's Avatar
My fogs stay on with full beam - 1998 EU continental model...
Local laws are more relevant in the country of delivery than the EU guidelines... So Britain had a different lighting law compared to the rest of the EU...
Old Feb 14, 2016 | 11:23 AM
Jhartz's Avatar
Yes, there is something wrong in the translation: are you saying the lights, that tell you the switches are on, are not lighting? The actually lights, light: correct? The lights to the cruise control and sport transmission are also not lighting when you pull the high beam stalk? But, otherwise they light?
You need to grab the electrical diagram for the European version of the car and trace those circuits. Most likely, a fault in the multifunction switch.
Old Feb 15, 2016 | 02:01 PM
Bcrary3's Avatar
Nick
I hope I am understanding properly, so;
When you have the high beam/main beam (the dash indicator is illuminated blue)?
My car, when I have the fog lamps on (front) do not operate when just the parking lights are on OR when I have my high beam/main beam on. However the rear fog lamps are always functional.
Old Mar 7, 2018 | 06:42 AM
King Charles's Avatar
What bulb is it for the trip switch ?
Thanks !
brgjag
Aug 16, 2021 08:04 AM
jagtoes
Oct 31, 2016 12:38 PM
Lynn1970
Feb 13, 2016 03:46 PM
tomtomterrific
Feb 7, 2016 08:21 PM
