Tag lights not turning off on X308
Old Oct 26, 2020 | 02:18 PM
pepsii's Avatar
Default Tag lights not turning off on X308
Greetings. Looking for someone who can help out a little bit here.
So I'm working on a X308 and one of the problems I have with it is that when I turn the ignition off, the tag lights stay on. Don't really want to go to inspection to figure out what the problem is - want to fix her up myself - so I was wondering if any of you fellas knew what the problem could be.
Thanks in advance.
Old Oct 26, 2020 | 02:20 PM
pepsii's Avatar
Quick side-note: the tag lights turn themselves off in about 5 minutes or so.
Old Oct 26, 2020 | 04:12 PM
sov211's Avatar
Explanation needed: what do you mean by "tag lights"? Do you mean the license plate lights on the trunk lid? Or...?
Old Oct 26, 2020 | 04:34 PM
pepsii's Avatar
Yeah I mean the license plate lights. All other lights are good.
Old Oct 26, 2020 | 04:45 PM
jimbov8's Avatar
Check relay R3 in the trunk fuse box is switching off. Check the flap in the ignition barrel is closing when you remove the key.
Sinbad
General Tech Help
Jan 29, 2020 09:42 AM
rtbash
Feb 21, 2017 05:58 AM
whitney12
Nov 24, 2014 07:03 PM
1994jigglywirexj6
XJ40 ( XJ81 )
Dec 10, 2012 04:24 PM
KBatten
Sep 20, 2009 01:31 PM
