TCM, Fuel Pump, and shifter assembly replacement
Old Dec 16, 2022 | 03:48 PM
Parker1807's Avatar
Default TCM, Fuel Pump, and shifter assembly replacement
2004 Xj8 is in the shop due to code p0705(transmission range sensor) and p1000(system check not complete)
Shop is saying that the TCM needs replaced, fuel pump needs replaced, and shifter assemnly needs replaced. They are quoting it at $8,400. Do you guys think thats accurate? Also, they are saying the fuel pump is out, but the car starts, i just cant move the shifter.
Old Dec 16, 2022 | 04:38 PM
aquifer's Avatar
You'll want to post your question in the x350 forum. This is the x308 group.
Old Dec 16, 2022 | 10:52 PM
xalty's Avatar
they’re telling please you go away or we will scam you.
used tcm from 04 NA car will start. range sensor can be repaired but takes skills so no point
Old Dec 17, 2022 | 10:57 AM
RandyS's Avatar
You could just get a different X-308 car for that.
Emil Wojcik
Mar 26, 2021 03:53 PM
plums
General Tech Help
Jan 17, 2016 02:28 AM
Toybreaker
Nov 17, 2015 03:22 AM
michaelnv
May 23, 2012 12:12 AM
