With these codes I'd assume I just have to swap the one ignition coil correct?
Old Aug 2, 2023 | 04:45 PM
MathisJag-2000's Avatar
Default With these codes I'd assume I just have to swap the one ignition coil correct?
My xjr recently went into restricted performance and I was thrown these code which seem pretty straightforward, so all I need to do is swap the ignition coil on cylinder 3 correct? Does any have a diagram of the order of the cylinders?
Old Aug 2, 2023 | 07:59 PM
motorcarman's Avatar
Info for you.
File Type: pdf
Old Aug 5, 2023 | 02:09 PM
Markus x308 3.2's Avatar
If one is broken, soon others will follow, if you have the money, replace them all.
XJ8JR
Jun 12, 2020 06:23 PM
Ross Von Brobyn
Apr 29, 2020 08:26 AM
Gribblet
Dec 2, 2012 04:21 PM
SirJag
May 27, 2011 08:49 PM
Iconoclast
Nov 29, 2010 01:20 PM
