throttle body with air assist
Old Apr 8, 2013 | 09:09 PM
kmm597's Avatar
Default throttle body with air assist
my throttle body junked out (99 xj8). I ordered a new one and this one has the air assist where my ild one dose not. Question is, its just a vaccum port right? Can I just tap into a vaccum place and stick a hose on it?
Old Apr 10, 2013 | 10:21 PM
spuddyo's Avatar
Are you referring to the black cylinder on the top with a vac connection? That would be the cruise control bellows used on AJ26 engine throttle body.
If you have no cruise control just leave it disconnected, if you have the later electronic cruise control you may have the wrong throttle body for that.
Old Apr 11, 2013 | 10:38 AM
dsnyder586's Avatar
Pretty sure you have the wrong TB on order. (they are not interchangeable)
I *think* 99 was the year with the switchover. FROM vacuum cruise TO electronic cruise)
If you can take pictures of both and post links to the pics we can tell you for sure.
Old Apr 12, 2013 | 04:47 AM
Sean B's Avatar
Yep - wrong tb, you'll need the earlier version mentioned. It won't work because of different electrical programming.
tbird6
Aug 13, 2024 07:50 PM
Gus
Oct 15, 2019 12:29 PM
ajacks86
Oct 12, 2017 08:51 PM
mrplow58
Sep 9, 2015 11:27 AM
