Throttle delay (power comes a second after pressing pedal) - any way to adjust this?
Old Feb 14, 2011 | 04:58 PM
vdpnyc's Avatar
Question Throttle delay (power comes a second after pressing pedal) - any way to adjust this?
It is less than 1-second of delay, but instant response would be nice. Is this normal for a non-supercharged XJ? Any way to tune/adjust it?
I have driven cars with a much longer delay. Both late-90's Dodge Ram 5.4 liter and Mitsubishi Galant 2.4 liter could count one-one-thousand-two before the power would kick in.
A new '10 Saab Aero is like a Jag in restricted-performance limp-home mode every time you hit the gas until the turbo kicks in some 3-seconds later. That Saab is an excellent $15,000 car - too bad it sells for $40k
Old Feb 14, 2011 | 06:18 PM
test point's Avatar
The only related throttle issue that I am aware of is to adjust the throttle cable where it operates the throttle position sensor. Many have tightened up the slack in the cable for a little more throttle response. Push down on the bare cable with your finger and see how much slack there is before the TPS moves. Needs a little but not much.
That probably doesn't specifically and completely address your issue/question but may have a positive affect on throttle response.
hafren
23
Jan 3, 2025 11:26 AM
mrplow58
Sep 9, 2015 11:27 AM
avern1
Sep 8, 2015 06:25 PM
hen555
Sep 7, 2015 11:13 PM
XJsc-guy
Sep 2, 2015 11:43 AM
