throttle position sensor / trans relationship
Old Feb 28, 2012 | 08:53 PM
domer94's Avatar
Default throttle position sensor / trans relationship
im trying to resolve a rough downshift issue , also when pulling a hill and backing off the gas, the trans hasnt been shifting into a higher gear , yet staying in the current gear as if i had a "shift hold" button. trans upshifts smoothly, but sometimes is slightly harsh when pulling to a stop and shifting back inti first. could a TPS cause or improve the interaction between speed and gears?
thanks
Old Feb 28, 2012 | 10:14 PM
Boomer from Boston's Avatar
Just as a long shot, there is also a throttle cable adjustment that needs to be correct, that can sometimes cause some of these symptoms. As the cable gets old and stretches, the throttle pedal does not necessarily correlate with the throttle plate position. Anyway, do a search on throttle cable adjustment. It's easy to do, so at worst you would be out a bit of time.
Jandreu
Jun 30, 2022 03:10 PM
mawheele
Oct 7, 2020 05:38 PM
Aus V8S
Nov 13, 2015 11:01 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
gregster41
Sep 6, 2015 06:51 PM
