A tiny tip to check on transmissions
Old Mar 8, 2012 | 02:20 AM
popeye68's Avatar
Default A tiny tip to check on transmissions
I found this quote on a transmission service website :
"The bolts on the transmission valve body should also be tightened to the specified torque. As the valve body gasket shrinks, from heat and depleted fluid, cross-leaks can develop among the passages. This can cause transmission failure and sometimes be prevented by this step."
Sounds reasonable , with all the pressures inside the valve body.
Could be vital in some cases , to prevent failure and damage.
AGCO Automotive Repair Service - Baton Rouge, LA - Transmissions
Old Mar 9, 2012 | 08:21 AM
xjay8's Avatar
Man!!....AGCO....what an amazing place!
There's a few service centres around here that could learn a thing or to from these people ;o))
Cheers,
Maximus
aholbro1
Dec 29, 2024 06:46 PM
bamforp
Aug 14, 2024 05:36 PM
Daim
Nov 28, 2016 09:28 AM
ahunt4
Sep 14, 2015 08:17 PM
KarimPA
Sep 12, 2015 08:15 AM
