tranny noise after fluid/filter change
Old Sep 26, 2008 | 11:57 AM
ilovetrains's Avatar
Default tranny noise after fluid/filter change
Changed the tranny fluid/filter in my 02 XJ at 80K miles. Well, had a shop do it for me with parts from Ken at Brittish MotorSport. Fluid looked horrible coming out.
Since, I get a turbine like noise when accelerating crisply in low gear or from low RPM. Basically it is not there if light acceleration and gets better with harder acceleration. It is not present at higher RPM. This makes me think that it is not developing sufficient pressure, however the tranny is full of fluid, so the obvious may be ruled out.
Suggestions?
Old Sep 27, 2008 | 09:00 PM
oldmots's Avatar
Default RE: tranny noise after fluid/filter change
The tranny could be overfilled. It takes someknowledge and the right tools to get the level right. I would see to ths before going anywhere else.
Old Sep 27, 2008 | 11:33 PM
dougs02's Avatar
The fluid should be at 86 degrees F (30 degrees C) when it stops trickling out of the fill hole. Never more than 122 degrees F (50 degrees C). Source, alldatadiy.
Doug
Old Sep 28, 2008 | 10:27 AM
JagtechOhio's Avatar
Greetings Trains,
It would be really beneficial to know what type of fluid was pumped into your transmission. I only use the specified Esso transmission fluid, and have never had a negative consequence...
so I can't offer any knowledgeable advice on the symptom you're having now.
Old Sep 29, 2008 | 11:13 AM
ORIGINAL: JagtechOhio
Greetings Trains,
I purchased the fluid from Ken at British Motorcars. It is not the Esso - but the alternative they recommend.
Old Sep 30, 2008 | 01:19 PM
wilson18067's Avatar
Have a look at this link.
http://www.bimmerboard.com/forums/posts/29693
Old Sep 30, 2008 | 03:18 PM
yikes - now I worried about the filter. Time to get it looked at.
tomsjag
Jun 10, 2023 10:02 AM
neruda
Oct 18, 2015 01:19 PM
Horus
Sep 18, 2015 05:39 AM
hen555
Sep 7, 2015 11:13 PM
innzane
Sep 2, 2015 10:08 AM
