Transmission drain plug?
Old May 27, 2016 | 11:04 PM
LowellLamb's Avatar
Default Transmission drain plug?
Finally found a shop (local garage) willing to put in a Transgo pressure valve update into the valve body.
So, presented for your consideration...
Looking at Trans filter kit, notice it has a replacement drain plug. Have not seen any mention of a drain plug on our Jag 5hp24 trannys, so thinking maybe the BMW 5hp24's have a drain port. Pending suitable research, might it be an idea to put on a BMW pan? Seems like it would make future changes of the "lifetime" fluid more pleasureable. Thinking shorter term fluid drains to dilute out residual converter remains.
Old May 27, 2016 | 11:53 PM
LowellLamb's Avatar
Um, of course, completely ignore this if our Jag pans already have a drain plug. I have not actually looked yet, but just saw a ZF rebuild pdf that indicates one.
Old May 28, 2016 | 03:56 AM
BobRoy's Avatar
Yes the zf5hp24 transmission has a drain plug that is easy to see once you look at the bottom of the pan.
vsol
Apr 15, 2016 07:11 AM
schippah
XJ XJ12 ( X305 )
Apr 7, 2016 06:07 AM
Travis O'Gallagher
Apr 3, 2016 02:49 PM
