Transmission extractiom
Old Apr 26, 2025 | 07:33 AM
13was13's Avatar
Default Transmission extractiom
Hi,
does anyone has some good advice of how to pull the transmission out of a 2000, xj8, 3.2 with a seized engine? So far I've tried pouring WD into the spark plug holes, and taking out the camshafts to no avail. The engine won't turn even with a gigantic breaker bar. No chance to access the flywheel bolts. There is a lot of burned oil ion the pistons and on the camshaft. One upper chain tensioner was damaged. So how should Iproceed?
Old Apr 26, 2025 | 08:11 AM
motorcarman's Avatar
I pulled the gearbox out of one of my parts cars with a seized engine (1999 VDP) by tilting the gearbox/engine enough and leaving the torque converter on the engine.
Years later the torque converter is still on the engine in the parts car!!!!!!!!!!!
Tilt down and straight back.
Old Apr 26, 2025 | 12:40 PM
13was13's Avatar
Thanks, I`ll try.
my spare transmission sits also on a car I bought for parts. I got it cheaply because the engine was toast. Never looked into it until now. Now my running car (350000) km has transmission problems: :ugly sounds, hesitiation before getting into gear, reverse works , then just the 4th in limp mode, which actually works fine .
I am no transmission expert, so maybe the converter on my runner could still be Ok?
Advice appreciated!
Old Apr 26, 2025 | 01:58 PM
I just used the converter from the faulty gearbox that came out of the original car.
It just had the common broken forward drum but I replaced the drum in the replacement gearbox before I installed it in the car.
KKJMG
Jan 29, 2023 07:34 PM
Christian 96 XJR
Apr 29, 2022 12:48 PM
user 732038
Nov 22, 2021 09:34 AM
christb01
Nov 14, 2021 03:08 PM
Forceofhabit
May 24, 2011 07:40 AM
