Transmission lurch problem?2000 XJ8 Vanderplas
Old May 23, 2012 | 08:15 AM
Forceofhabit's Avatar
Question Transmission lurch problem?2000 XJ8 Vanderplas
Ok....Last night at a stoplight my transmission in my 2000 XJ8 Vanderplas slipped and then caught. Thought I got rear ended?! Pulled into gas station and checked it out....No fluid leaking, NO warning lights....Still drives but very slow like a bad slip....Still have full power in reverse...What are my options? I had my car towed home to prevent any futher damage... Is this a fatal sign for my tranny or is this a 'flash' issue and easily fixed? Please help, its my only car!
Old May 23, 2012 | 08:26 AM
motorcarman's Avatar
Low fluid or a broken forward ('A'drum) will cause that fault.
I had a customer's car for the same fault and 2 other shops (one the Jag dealer) told him he needed a new gearbox but it turned out to be a cooler line leaking and low fluid level.
A good used gearbox might be a less costly option.
You can replace the 'A'drum if you have the tools/skills.
Check the fluid level and go from there.
bob gauff
Old May 23, 2012 | 08:28 AM
will do Bob.....Thanks!
Old May 23, 2012 | 08:29 AM
Im hopfull because NO warning lights have lit up....
Old May 23, 2012 | 08:51 AM
Default where do I check my tranny fluid level at? 2000 xj8
Old May 23, 2012 | 09:48 AM
Is there a sticky note on how to check the tranny fluid level? I see one for x type....
Forcedair1
Sep 8, 2025 01:57 PM
obwoodie
Sep 3, 2015 07:45 PM
pocketrocket
Sep 3, 2015 07:44 PM
laserguy
Sep 3, 2015 02:02 PM
XFR_Gold
Sep 2, 2015 12:24 PM
