Transmission - Is this normal?
Old May 13, 2007 | 10:02 AM
FL XJR's Avatar
Default Transmission - Is this normal?
My car shifts very smoothly (like buttah ) and I dont notice any issues under normal driving conditions. However, push it a little off the line and as it shifts through the gears there is a hesitation between gears as it "thinks" about shifting. I have never noticed this delay in an automatic before. In other cars, the nextgear is always right there - zip, zip, zip through the gears. Honestly, it's a little annoying - you get great take-off, then loose "oomph" as it decides to shift into the next gear, then, zoom again, loose oomph, (shift), zoom. WTF? It feels just like I am riding in astickshift car. Isthis phenomenonnormal in anXJR? (BTW, itdoes it whetherit's in sport or normal mode.)
Old Jun 27, 2007 | 10:52 PM
FL XJR's Avatar
Default RE: Transmission - Is this normal?
After I noticed my car was shifting strangely (hesitatingly)under harder accelleration, the "restricted performance" warning light started coming on intermittently at first, then more often. I finally took it to the dealer and they said the fuel psi wasbelow spec under hard accelleration. Theyperformed a throttle body cleaning (though I had already done that and it was whistle clean). Thentheyperformed a fuelservice which included a new fuel filter. Man, whatta difference!The car shifts beautiflully, even when I stand on the accellerator through all gears! It's like my car has been reborn!
aholbro1
Dec 29, 2024 06:46 PM
PlatinumJag
20
Oct 2, 2020 02:23 PM
CXJ
Nov 28, 2015 11:41 PM
SouthernGypsy
Sep 23, 2015 04:06 AM
ayavner
Sep 14, 2015 07:41 PM
