transmission swap
Old Mar 22, 2015 | 02:14 PM
batson58's Avatar
Default transmission swap
will a 2000 xj8 transmission fit a 1998 xj8 both have 4.0 v8 thank you for any help or advise
Old Mar 22, 2015 | 05:59 PM
mikebaker3's Avatar
I believe all XJ8s that are normally aspirated use the same trans
The supercharged cars use a different trans
Old Mar 22, 2015 | 07:03 PM
motorcarman's Avatar
I have swapped AJ26 gearboxes into an AJ27 and 'vice versa'. I have read where a forum member did this and reported having to swap valve bodies or internal harnesses to rectify a gearbox fault indication.
They do have different part numbers but like I stated...... I have done the swap with good results.
If you have both boxes then you have all the parts needed if a fault arises.
bob gauff
Old Mar 23, 2015 | 07:59 PM
Lear45's Avatar
That should not be a problem I had mine rebuilt and installed fo5 $2,600. Safer than an unknown junkyard transmission. Get a rebuilt valve body and A drum at a minimum and you will save yourself problems later. Spend a little more and have dependable car.
As long as the newer transmission has a good maintenance history life if good.
Old Mar 26, 2015 | 08:48 PM
batson58's Avatar
the trans I have was reman. for 4800.00 with life time warranty so was planning to try and find a jag with bad tranny to put it in, thanks for all the input very helpful
aholbro1
Dec 29, 2024 06:46 PM
Jagged-X
Sep 24, 2015 05:08 PM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
mrplow58
Sep 15, 2015 09:58 PM
jerry_hoback
XJ40 ( XJ81 )
Sep 13, 2015 07:48 PM
