Tricky rattle/noise to diagnose
Old Jun 6, 2011 | 08:11 AM
motorcarman's Avatar
Most people just replace the secondary (upper) tensioners but I have had the primary (lower) ones fail and the guide blade will 'rattle'.
Here are some TSBs to look at.
bob gauff
File Type: pdf
Old Jun 6, 2011 | 01:08 PM
Leedsman's Avatar
You have a tricky one there Anthony. It sounds from your description that it might be combustion noise; so for a while try a different petrol. It's not going to cost anything in either money or time, and will eliminate one thing. If different petrol does make a difference to the noise, then at least you're in the right area. You would then start looking at faults in the knock sensor (if it has one) as an example, or anything affecting ignition timing/knock-ping. Even wrong spark plugs.
It's so hard to make any diagnosis just from a description, but one enterprizing contributor posted an audio file of his irritating noise. I wonder if he ever got shot of it?
Leedsman.
RaceDiagnostics
Jul 7, 2022 06:41 AM
jazzman20014
Oct 26, 2015 04:15 PM
inactualis
Oct 2, 2015 11:13 AM
yeldogt
Sep 27, 2015 01:57 PM
swetnK
Sep 24, 2015 07:55 AM
