trunk latch fix
Old Apr 20, 2013 | 07:51 PM
yardpro's Avatar
Default trunk latch fix
i did a lot of searching and could not find an answer.
My wifes car trunk quit latching....could not find anything on this problem..
I took the latch off andfound that it needed to be lubed and worked back and forth... viola fixed...
I figured i would do a mini write up in case someone else has the same problems..
  1. open the trunk
  2. place a flat screwdriver under the trunk lid carpet at the pins and pry them out to release the truk lid carpet.. or whatever you call it
  3. remove the three bolts that retain the trunk latch.
  4. remove the emergency handle from the release cable and feed it through the slit in the carpet.
  5. unlug the wires that run to the latch
  6. disconnect plastic clips from the actuating arms
  7. pull out the latch assembly and lube the shiny metal arm that the arms attached to
  8. work latch back and forth until the spring tension will return it on its own tension
  9. reinstall and have a beer
Old Apr 23, 2013 | 11:31 PM
YoungRobertL's Avatar
A couple of questions. Would this work if the trunk is NOT unlocking? I see a mention of an "emergency handle"...can this unlock a trunk that won't open? I'm at a loss here...just all of a sudden the trunk would not unlock with the key (it quit working with the inside button months ago when I pushed the "valet" button, & have not been able to "un-valet" it...but just used the key, until now. Bob
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
findre
Sep 10, 2015 05:46 PM
Jay48
Sep 7, 2015 09:30 PM
