Trunk latch removal/fix
Old Oct 7, 2013 | 02:22 PM
Porsche407's Avatar
Default Need Help! Trunk latch removal/fix
I'm fixing my 2 trunk lights and in order to get to where I need to go , I have to remove the trunk latch. Here's my quandary... Latch pops and opens from the inside button, the key fob, and the button in the rear but won't open with the key! It does turn all the way however the latch doesn't release. Is it a quick fix? If so... any suggestions? Do I simply undo the 3 star bolts and move it to the side to remove the trim? Could use a diagram, had it off it appears the clips holding the arms are fine... How to I adjust the key one?
Thanks as always... Great forum!!!
bdboyle
Nov 6, 2015 02:07 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
magmedia
Oct 8, 2015 03:28 PM
millertic
Sep 30, 2015 08:11 PM
