trunk lift struts
Old Nov 17, 2012 | 09:55 AM
yeldogt's Avatar
Default trunk lift struts
It was a bit cold this morning and I noticed that the trunk supports are getting weak -- anyone replace them? Normally they are easy when you can get to them.
Just wondering before I pick up a set .......Autohaus has them for around $45 each -- so not too bad.
Old Nov 17, 2012 | 11:00 AM
Doug's Avatar
I'm assuming (ha ha...yeah, I know) the X308s are the same as the X300s in this area.
I replaced mine a year or two ago and, though perfectly DIY-able, it was actually a bit more difficult than I expected. I had difficulty disengaging the old supports where they attach under the package tray area, especially on the RH side. Very little space to properly release (or even pry off) the retaining clips.
I can't remember the exact details but at the end some anger, brutish tactics, and blood loss were involved.
If there's a special technique involved let's hope someone chimes in with it :-)
magmedia
Aug 15, 2019 08:54 PM
dmatthewman
Sep 30, 2015 10:10 AM
Collector1
Sep 28, 2015 03:52 AM
HuncaMunca
Sep 27, 2015 02:47 PM
