Trunk Light Dangling.
Old Apr 23, 2017 | 01:38 PM
omgimali's Avatar
Default Trunk Light Dangling.
The trunk/boot light is dangling from the liner and it seems that the glue from the leather is let loose that is connected to the liner. the glue is dried. Will Gorilla Glue work just fine? or something else?
Old Apr 23, 2017 | 02:28 PM
avern1's Avatar
It is not supposed to be glued in. The light frame should have tabs on the small ends. The tabs are what is supposed to hold it in place. If the tabs are broken off then I would look for a new light at a junk yard. If they are still intact then the last person to work on tore the opening in the trunk liner. I have ccut a rectangular donut out of thin plastic and used it to reinforce the trunk liner opening from the backside.
If you want to just glue it back in and hope the bulb last as long as you have the car you will need to find an adhesive that will withstand high temp when the sun heats up the metal trunk lid. Somethiing like auto trim adhesive that they glue the plastic trim to the sheet metal.
Old Apr 23, 2017 | 02:34 PM
King Charles's Avatar
Yea I have that as well, thanks for reminding me to fix it lol.
If you go the glue route be sure to change the bulbs to LEDs so they're likely good for life.
Old Apr 23, 2017 | 02:37 PM
omgimali's Avatar
Tabs are different from what i am talking about. I am talking about the leather connected to the liner.
Old Apr 23, 2017 | 07:17 PM
ericjansen's Avatar
Yes, you are right, the leather surround is glued in there, then the fitting is clipped in.
I glued the leather surround back with some 2 component stuff, worked well, just be sure to position it well before it dries.
If I remove the liner (had that to do that several times hunting a limit switch malfunction long time ago), I take care to loosen the liner a bit on one side, then get one hand in, and carefully push the fitting out, applying some pressure on the leather to prevent ripping again, same for installing.
Holding some 2 1/2 years by now.
Old Apr 23, 2017 | 07:26 PM
omgimali's Avatar
There is old glue on there. Should I remove that? the glue is on the far edge. If I remove it how so?
Old Apr 23, 2017 | 07:56 PM
ericjansen's Avatar
I honestly forgot, but was it that brownish stuff, bit glass like?
I think Jaguar originally used heat gun glue or something like that.
I think I scraped off the loose stuff, sounds logical, but can't remember I spent a very long time on it, as the glue is not visible after doing so (unless you do an improper job .
Old Apr 23, 2017 | 08:10 PM
omgimali's Avatar
Thanks!
