Upper Cam Tensioners.
Old Jan 22, 2023 | 12:08 PM
mcook's Avatar
Default Upper Cam Tensioners.
Just a quick question.
What was the model year when Jaguar stopped using the plastic tensioners on the XJ8/XJRs and switched to metal ones?
Thanks.
Old Jan 22, 2023 | 04:02 PM
Z07Brandon's Avatar
2002. After September, I believe.
Old Jan 22, 2023 | 07:19 PM
mcook's Avatar
Thank you!
Old Jan 22, 2023 | 07:42 PM
motorcarman's Avatar
ENGINE NUMBER is the ONLY way to verify. The engine was ALWAYS made before the car!!!!!!!!(VINs are WORTHLESS)
(what if the engine was replaced?)
August 13, 2001; engine S/N 0108130000 onward were supposed to have the metal body tensioners.
0108130000 = 2001 year, 08 month, 13 day, 0000 hour.
Old Jan 23, 2023 | 06:17 AM
mcook's Avatar
Thanks. I am looking at a 2005 M.Y. XJ8 L to possibly purchase. I will see if I can get the engine number.
Old Jan 23, 2023 | 06:29 AM
Hooli's Avatar
2005 is a X350 I think, you'd be better off asking in that section of the forum but I don't believe they had the same tensioner issues.
Old Jan 25, 2023 | 11:53 AM
PeteK812's Avatar
What about the lower tensioners? Did they figure out how to fix that problem at the same time? Seems like the plastic that didn't enjoy hot oil was at fault in uppers and lowers.
Old Jan 25, 2023 | 03:03 PM
87LC2's Avatar
That would be an x350 as others have said. By that time all AJ engines had metal tensioners, no need to worry.
Jtestrake
May 4, 2026 09:16 PM
barriectaylor
Apr 5, 2025 01:41 PM
O&DR
Sep 13, 2022 04:56 AM
Fyrplg
Oct 19, 2021 06:15 PM
EZDriver
Apr 19, 2011 11:32 AM
