Vandan Plas 1999 OBD II Connector Location??
Old Jul 5, 2010 | 08:37 AM
ka1thm's Avatar
Default Vandan Plas 1999 OBD II Connector Location??
Can anyone tell me if a generic OBD II Code Reader will work on this car, and where the connector is located to plug in?
Thank you
Old Jul 5, 2010 | 02:04 PM
test point's Avatar
There is a thread in the 'General' section discussing OBDII readers. Most work but have limitations.
https://www.jaguarforums.com/forum/s...ad.php?t=33347
The data port on the XK8/R is directly above the hood/bonnet release lever. Don't know about the XJ8/R series.
Old Jul 5, 2010 | 04:31 PM
hrand1987's Avatar
Please delete
Last edited by hrand1987; Jul 5, 2010 at 04:36 PM. Reason: Admin please delete - trouble posting from iphone
Old Jul 5, 2010 | 04:32 PM
hrand1987's Avatar
I hooked up an acutron, pre can, obdii reader a couple weeks ago to adjust my throttle slack and had no problems. The port was on the deivers side of the center console, under the dash facing the floor, i would imagine yours is the same way.
Btw check your throttle slack if your scanner works. Mine was reading 85% floored and 95% really jammed into the carpet which i never push that hard when driving. Adjust it from the engine bay by cutting the zip tie and rethreading the metal throttle cable sleeve. Make sure to check both your WOT and especially your idle. My car idles at about 750 an still has 100% WOT. Also be sure to reziptie the cable!
Old Feb 18, 2024 | 02:59 PM
Elmo1544's Avatar
On the 1999 Jaguar XJR the port is just in front of the gas pedal pointing down.
Old Feb 20, 2024 | 12:41 PM
hispeed42's Avatar
Did you do a hard reset after the cable adjustment? If not, doing so will reset the ECU so it knows where "zero throttle" is and set the idle back to 650. You'll still have the 100% WOT.
philwarner
25
Jun 26, 2021 05:43 AM
cissdm
May 3, 2016 06:02 AM
copyman01
Nov 1, 2015 01:01 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Bob Gelston
Sep 14, 2015 11:08 PM
