vdp 2001 dtc p1646.
Old Apr 2, 2008 | 08:14 PM
FactoryJaguarTech's Avatar
Default RE: vdp 2001 dtc p1646.
Do you have a s/c car? You say VDP but is it or is it a SuperV8?
If it is supercharged, replace the relay. Clear the code and drive it again.
Old Apr 2, 2008 | 10:41 PM
JagtechOhio's Avatar
FJT, I saw this one too and scratched my head. Moisture in the empty relay socket? What about plugging a relay in, surely the supplementary fuel pump harness is insulated, and it would never get a signal to energize from a non-S/C ECM? Just goin' fishin'...
Old Apr 3, 2008 | 06:42 AM
Those are possible. Could also be that the ECM was replaced with s/c one? Look at part number on ECM and compare it with the vcats label in the trunk by spare tire. Maybe under left side trunk carpet.
Old Apr 3, 2008 | 07:43 PM
jag_genius's Avatar
thats a head scratcher..
Old Apr 3, 2008 | 08:02 PM
jag_genius's Avatar
it seems like your car has the worng ecm in it or ... ive seen on newer cars.. if you program a car as a super charged.. and it doesnt have a super charger it will think it has one and give all these error codes for missing components like intercooler sensor missing or open circuit and 2ndmass airflow sensor missing and IAT 2 missing or open circuit.. have seen these things on new xk's . also it can be if your car started out as a xjr and was converted back to a N/A engine .. which is heavy in cost and pretty stupid to do..and high unlikely.. lol . putting a relay in there wud not do anything cause in you harness there is no number 3 pin in connector EM82 where the fault is happening cause the ecm is looking for a relay resistance but can't find one.. you can wire up a resistor.. give me your last 6 of your vin i wanna check something .
Old Apr 6, 2008 | 09:55 AM
Programmingthe ECM should only cost you 1/2 hour labor at dealer. Would be worth a shot.
Old Apr 7, 2008 | 06:27 PM
jag_genius's Avatar
sounds good.. sorry for the wait.. was out of town.
Old Apr 8, 2008 | 06:54 PM
I looked up the VIN too.....never was a S/C car.
Old Apr 8, 2008 | 07:15 PM
good luck Rick.
Old Apr 8, 2008 | 08:38 PM
jag_genius's Avatar
hope it works out
Old Apr 10, 2008 | 07:20 PM
The o2 sensors are in the cats. Not a terrible job, but not my favorite either.
Hard to say without the car and diagnosis myself.
Old Apr 10, 2008 | 07:43 PM
jag_genius's Avatar
sounds like the ecm is toast.
Old Apr 10, 2008 | 09:08 PM
Agreed.
