View Poll Results: Driveline Vibration XJR
Mounts - engine
0%
Driveshaft - U Joints
66.67%
Mounts trans
0%
Wgheels and tire
33.33%
Voters: 3. You may not vote on this poll
Vibration
Old Jun 6, 2009 | 10:03 PM
Markus's Avatar
Jaguar dealers have a very sophisticated vibration analyzer. If I were you, I'd bite the bullet (and this comes from an owner who has experienced nothing but ill-service from 5 different Jaguar dealers since buying my XJR new, and who has not darkened the doorway of a Jaguar dealership for 6 years), and have them diagnose it.....
________
1999 XJR
Old Jun 7, 2009 | 09:08 AM
sanand911's Avatar
I would first start with making sure my tyres are balanced. I have had the same problem once and balancing them did the trick. I doubt it's anything big like joints though on my previous car (2001 Jag XJ8 Super V8) I did have to change a bearing at 60K
________
Ford Expedition history
Old Jun 9, 2009 | 02:53 PM
JackJohn's Avatar
Tim, based on your description of the problem, I will lean toward the drive line. But like Markus recommended, bite the bullet and have it checked out. You can spend a bunch of money changing things out to find a problem like that.
Old Jun 9, 2009 | 09:12 PM
jag_genius's Avatar
i wud check the u joints.. and rear wheel bearings.. and check the lower fulcrum bearings.. the casing likes to explode if never serviced.. depending on mileage
Old Jun 9, 2009 | 09:17 PM
jag_genius's Avatar
engine mounts leak when they go.. and xjr drive shafts are usually good
yoiyoi
Dec 19, 2023 12:51 AM
Inspector
Oct 17, 2015 12:51 PM
BathoryFan
Sep 15, 2015 05:04 PM
hen555
Sep 7, 2015 11:13 PM
